Something to keep in the back of your head is that you can do this with a higher accuracy RTD and a good multimeter which can do 4 wire measurements. Some bench multimeters will read in degrees if you tell them you have an RTD plugged in. So if you need or have a good multimeter anyway, this might be a solution.
