Another question about this device. I build the circuit on Figure 31, with RFB=442 and RG=44 and the 1uF two capacitors.
My input signal is a 700kHz 1Vp_p sinusoid. In output a see a 50-60MHz sinusoid, and it is not amplified. What do you think I might be doing wrong?
Indeed I see the 60MHz output even though there is no input. So if the input is there or not, doesnt change the output
I'm attaching a sketch of the circuit
