Thanks ve7xen, how would I "enable" the comparator?
Thanks Mechatrommer, I did read this, on a reread the schematic was useful:
https://dl.dropbox.com/u/28207218/generator/Schematic%20Prints.pdfThe schematic is missing the E6 SMA, I am guessing that is for an external clock because it's right beside the 30Mhz crystal and seems to be plugged on the ebay and taobao images?
I can't tell what the E3 SMA is used for it looks like it is only connected to 36 and 42 on the AD9854:
36 VOUT Noninverted Output of the Internal High Speed Comparator. Designed to drive 10 dBm to 50 ? load as well as standard CMOS logic levels.
42 VINP Voltage Input Positive. The noninverting input of the internal high speed comparator.
So E3 is a comparator SMA connector, not sure if its an input or an output, how would I use this?
Also can somebody help me understand the theory behind pins 48,49,51 and 52, what are the complimentary pins all about, all 4 pins seem to each have a seperate SMA connected E1 thru E4:
48 IOUT1 Unipolar Current Output of I, or the Cosine DAC.
49 IOUT1 Complementary Unipolar Current Output of I, or the Cosine DAC.
51 IOUT2 Complementary Unipolar Current Output of Q, or the Sine DAC.
52 IOUT2 Unipolar Current Output of Q, or the Sine DAC. This DAC can be programmed to accept external 12-bit data in.
When would I use the outputs, I assume IOUT1 and IOUT2 are both capable of independently outputting a wave, if so, I will need a second SMA to BNC to attach the board to my oscilloscope CH2?
JP2 looks like it is an ISP programming interface for the ATMEGA. I am slightly annoyed that the only pins I have are JTAG and ISP, I though there might be some of the spare ADC pins on the ATMEGA (like ADC0-ADC3) would be broken out so I could attach switches and maybe a rotary encoder, having to add a second MCU to it to accomplish this is a PITA. I guess adding an LCD, rotary encoder and some function switches would probably need more than the remaining pins on the ATMEGA anyway?
Thanks again, between the forum, datasheets and google... I am getting there.
Richard
