I rewound a toroid ( it had been cooked rather well by a shorted secondary) and converted it into a current transformer, using only the core and the plastic end caps, then making a new secondary of 12 turns of 2.5mm wire and then simply had a primary pass through it. Connected to a 5A AC ammeter and it did sterling duty to measure incoming mains current. It originally was used for a 50W downlighter, so no problem here of core saturation, it probably would have worked up to 1kA primary current, though I would have had a hard time getting the 200 turns of wire through the centre along with the 35mm primary wire.
