Author Topic: Adding regulated outputs  (Read 1145 times)
Offline sk614
« on: July 26, 2016, 06:41:28 am »
I have two voltage regulator that convert to 3.3V.  Is it even possible to add them together to get higher voltage?
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Adding regulated outputs
« Reply #1 on: July 26, 2016, 06:42:29 am »
if they share the same ground, NO.
https://www.simonselectronics.co.uk/shop New stock now in of EEVblog 121GW and Brymen 235 Now selling a selection of Probe Master probes.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Online Zero999
  • Hero999
« Reply #2 on: July 26, 2016, 07:03:46 am »
It depends on the regulator: Part number? Datasheet?
Offline MosherIV
« Reply #3 on: July 26, 2016, 07:15:00 am »
Simple answer NO.
You can do it with 1 voltage regulator:
http://www.pcsilencioso.com/cpemma/diodes.html
Look at the 'fixed regulator' section and how it is possible to raise the ground pin.
It is also possible to do it with diodes and zener diodes.
Online Zero999
  • Hero999
« Reply #4 on: July 26, 2016, 07:53:55 am »
Simple answer NO.
Yes. It can be done, so long as the load on the regulator use to lift ground pin is equal to or greater than the current taken by the other regulator.
Offline sk614
« Reply #5 on: July 27, 2016, 06:56:23 am »
This is what I am using, a RF to DC convertor.  http://www.powercastco.com/test566alpha/wp-content/uploads/2009/03/p2110b-datasheet-v12.pdf
For reason not possible, why is that?
Offline Simon
  • Global Moderator
« Reply #6 on: July 27, 2016, 07:01:50 am »
your input and output needs to be isolated otherwise when you put them in series you will connect the ground of one to the positive of the other that has the same ground, thus short circuiting one of the outputs. If they are fed from isolated inputs you can put them in series or if they use a transformer making the inputs isolated from the outputs.
Offline suicidaleggroll
« Reply #7 on: July 27, 2016, 07:06:02 am »
That device doesn't give you a continuous 3.3v.  It uses the accumulated RF energy to charge a capacitor, then when it hits a set voltage it boosts it up to the voltage you want until the cap decays back down, and then it shuts off the output.  Since the output is intermittent, you can't stack two of them and expect to get 6.6v.  Most of the time you'd get 0, sometimes you'd get 3.3 from one device or the other, and very rarely (I'm assuming, I don't know your load or what kind of duty cycle you'd get from this device) you might get 6.6v.
The two devices obviously couldn't share a ground, you'd need to stack one of their grounds on top of the other's Vout, and then take care of the myrid of problems associated with doing so (your two RF antennas wouldn't share a ground, your digital signals wouldn't share a ground, etc).
