Author Topic: Adhesive to stick on a rubber pad  (Read 1492 times)
Offline jayco242Topic starter
« on: May 23, 2016, 10:46:39 pm »
  I will ask this in beginners as i am not sure where else this will go. I need to stick a large rubber pad onto the bottom of a few project boxes. Wikipedia says i need a removable adhesive. The pad would need to be removed to get at some screws. Obviously super glue is out of the question. does anybody know what I can use that is also accessible to general public? Gallon size or industrial quantities are too much.
  Thanks
    Jason
Offline Signal32
Re: Adhesive to stick on a rubber pad
« Reply #1 on: May 23, 2016, 10:53:24 pm »
Double sided tape / pads ?
http://www.ebay.com/sch/i.html?_odkw=double+sided+tape+removable&_sop=12&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR11.TRC2.A0.H0.Xdouble+sided+tape+.TRS1&_nkw=double+sided+tape+&_sacat=0
http://www.ebay.com/sch/i.html?_odkw=double+sided+tape&_sop=12&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xdouble+sided+pad.TRS0&_nkw=double+sided+pad&_sacat=0
Depends how strong you need the bond to be.
Or permanent glue some velcro on feet + case if you think you'll be accessing the screws all day long
But you're probably looking for the glue'y gel'y stuff that sticks but doesn't dry. I don't know the commercial name for that, I would be interested to find out.
« Last Edit: May 23, 2016, 10:56:43 pm by Signal32 »
« Reply #2 on: May 23, 2016, 11:07:20 pm »
Neoprene cement. Look for the type used either for wetsuit manufacture/repair or shoe* manufacture/repair. Depending on the type of 'rubber' you have it might need the surface treating either with a specialist primer or passing through an open flame before gluing.
*This type often goes under the name 'colle de cologne'.
Offline IanB
« Reply #3 on: May 23, 2016, 11:47:41 pm »
I would use something like this: http://multimedia.3m.com/mws/media/796078O/rubber-and-vinyl-80-spray-adhesive.pdf
(Which is indeed neoprene cement.)
I would punch holes in the rubber pad where the screws are.
Offline alsetalokin4017
« Reply #4 on: May 24, 2016, 02:21:35 am »
3M / Permatex Weatherstrip Adhesive. Available in yellow or black, at your car parts store.
Offline houdini
« Reply #5 on: May 25, 2016, 01:04:33 am »
+1 for weatherstrip adhesive.
Offline bitseeker
« Reply #6 on: May 25, 2016, 01:40:12 am »
+1 for punching holes in the pad for easy access to the screws.
