This is probably a dumb question but here goes -- I constructed a basic LC tank using a 68nF capacitor, and a hand-wound inductor of 5 turns with a diameter of 18 to 20mm or so. This works out to 0.2-0.7 uH or so based on online calculators (values rough because it's roughly made). So this should resonate at about 1 MHz or so.
I used a scalar network analyser to test the tank, with a 2.7k resistor from the tracking gen feeding the LC tank, and the LC tank connect directly to the signal analyzer.
I see a peak at 960 kHz, as expected, and I can reduce the frequency of the peak by a factor of sqrt(2) by doubling the capacitance, again as expected.
However, when I poke steel screwdrivers (which stick to magnets) and other steel thing inside or nearby the inductor, I see no change in the frequency -- the amplitude of the peak drops, presumably due to eddy current losses, but I was expecting an inductance change and therefore a frequency change.
Unfortunately I have no actual ferrite material to test with, but I thought steel would modify the inductance by at least a measureable amount; measurable even by my crude signal analyzer setup (crude compared to building an oscillator and using a frequency counter, of course). What am I missing?
