Hi all.
So currently I am using FFC cables to connect 3 boards together. The main problem is is that these are really hard to mount onto the board as I am soldering these all myself.
The room is so small on my boards that I am having to use 1mm cable which results in 0.5mm pin pitch on my circuit boards.
I am getting some boards made but yields are low.
What are my other options for board to board interconnect when you have very little room, not able to use hard connectors like pin headers etc?
Thanks
Jack,
