Author Topic: Am I alone in finding quality stereo through panel 3.5mm jacks hard to find?  (Read 1241 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
I need some decent quality stereo 3.5 mm through panel mount (threaded bush and a nut) jack sockets. I got some Lumberg brand ones from RS and unless you fiddle with the plug and pull it out a tad once fully home you don't get a decent connection. I checked with another make of stereo lead with different molded on plugs and it was the same, so I believe the issue is the sockets. Does anyone know of a good quality through the front panel jack socket I could buy here in the UK please? I am not a gold plated mains plug audiophile, they are for Softrock SDR receivers to take the I/Q outputs to my PC's sound card :)  Thanks!
Best regards,
                 Chris Wilson.
Offline Kjelt
No you are not the only one.
I used these for cheap connections to my 12V relais powering my 8 surround sound active monitors and found out that by wiggling a bit the relais start to toggle. Bad connection.
I think the metal versions are a bit better but I needed isolation.
The following users thanked this post: Chris Wilson
Offline tooki
Surely one of the 31 panel mount 3.5mm jacks in stock at Mouser.co.uk would fit the bill?!
Also, don’t underestimate how many 3.5mm plugs are actually out of spec...
Offline jh15
Can you elaborate or some links about this I can show? ? I've measured it myself, and Apple seems to be the worst in reliability for wear.
I do non-profit broadcast engineering, and many volunteers use mobile or laptop sources.
Wear and tolerances are a major issue with discrepancy reports, and now we have to enjoy bluetooth only connections from consumer crap.
All I-phones should be required to have xlr connectors if connected in a broadcast studio.
You just need a smaller a**for  pocket to put a thick device in.
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline stevelup
Never had a problem with these but they are stupidly expensive:-
https://uk.rs-online.com/web/p/products/6659585
We use them because they can be mounted in a standard cut-out - that said, what we actually usually do is fit 3 pole XLR socket and provide the end user with a cable with an XLR on one end and a 3.5mm jack on the other for connecting to the device. You could (should perhaps) consider doing that instead.
These look nice - worth a try and reasonably priced:-
https://uk.rs-online.com/web/p/products/5051429
As one of the other posters suggested though - are you sure it's not your leads?
Offline Zero999
  • 0999
I've just checked out Rapid Electronics.
This? Looks a bit cheap though and they only sell them in quantities of 10.
https://www.rapidonline.com/truconnect-pj-301dm-3-5mm-stereo-miniature-jack-socket-20-0133
Branded, more expensive, so might be better.
https://www.rapidonline.com/bkl-audio-jack-socket-3-5-mm-chassis-mount-sheilded-3-pin-stereo-50-1511
