Author Topic: Am I suppose to be able to select the oscilloscopes maximum memory depth?  (Read 1171 times)
Offline cvrivTopic starter
I installed the upgraded license I received with the purchase of my oscilloscope and the oscilloscope said it was installed successfully, but when I was poking around I noticed that my memory depth only went to 28Mpts. I checked the installed options and I think everything is enabled. Am I missing something here? Am I just not understanding this correctly? I attached some pics.
Also, are there more options available that I'm not aware about, that if I hacked this machine I would receive?
« Last Edit: June 23, 2016, 12:54:05 am by cvriv »
Offline tautech
Total memory may be divided by the # of active channels.
Avid Rabid Hobbyist
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
As tautech said. Your picture shows the two channels active and therefore the memory will be halved.
Ok. Makes sense. Thanks.
