Hi guys
I've been having a great time watching a few Dave teardown tuesday videos and was especially interested in the one for the Amiga 500.
Given that I have an Amiga 500 lurking around, I've decided to crack it open and have a look. It seems to be a later model (circa 1989/1990) board model 6A and has a 1MB - for a total of 1.5MB - (do I hear an "ooooooooohhh!" from the audience?) RAM upgrade board in it with a battery backed clock.
The battery for the clock is understandably shot (23/24 years can do that to a battery
) so I was thinking of replacing it. However, I cannot find a supplier in the UK that I trust who carries a 3.6v 50mAh NiCd battery, so I've hit on a plan to replace it with a near-equivalent one:
http://uk.farnell.com/varta/55608303059/battery-pcb-mount-3-6v/dp/279341From what I understand (and this is what I need to check with you guys) the following is true:
1) The mAh is capacity of the battery and as long as it exceeds the older battery's 50mAh then it should be ok (99% sure of this)
2) The battery will need to be 3.6v (I'm 100% sure of this one!)
3) The charging should be ok, although I should watch out for signs of over charging (getting excessively hot).
Are my above assumptions true and is there anything else I should be aware of? I don't watch to a) damage the Amiga, b) cause a fire and make myself homeless, c) have a battery explosion which somehow maims me(!).
Cheers for any advice!
