I have a project that requires 4-conductor wire.
My question is, can 60mA be safely pulled through a 28awg 7-wire stranded wire at 5 volts and through 50ft?
Realistically, it would be 45mA continuous with an additional 15mA every once in awhile (whenever a button is pushed).
Most of everything I find says yes. 360mA, but it doesn't say for what voltage or length of the cable.
The cable I am thinking of using is 28awg 4-conductor with a drain wire and foil shield AND a braided shielding (double shielded).
Thanks in advance,
Jason
