Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Amplifier static
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Amplifier static (Read 1402 times)
digitalnomadjc
Contributor
Amplifier static
on:
October 04, 2016, 12:53:53 pm »
Hi I have an amplifier question.
The details are going to be a bit light because someone else asked me.
The amplifier design is a known working solution. The PCB is a old fashioned home etched single sided board.
When the amplifier is powered with no input cable plugged in there is no static
when the input cable is plugged in and there is no signal there is static
when there is signal (such as bass/loud sounds) the sound is crackly.
I'm thinking dry solder joints or some sort of grounding issue. I haven't seen the board yet.
any ideas?
Logged
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Re: Amplifier static
Reply #1 on:
October 04, 2016, 04:16:27 pm »
Grounding in cable shields, grounding in general.
Old caps, especially electrolytics, possibility.
Use a scope and start on output stage and work backwards.
Regards, Dana.
Logged
digitalnomadjc
Contributor
Reply #2 on:
October 05, 2016, 02:33:36 am »
Thanks
Logged
digitalnomadjc
Contributor
Reply #3 on:
October 10, 2016, 11:57:55 am »
Hey I worked out what it was.
working backwards from the output we replaced the 2200uF Cap and discovered the trace had lifted. Then the LM1875T looks pretty sick and after confirming that the output was not producing anything and the input was ok we replaced that too.
After that it came to life. Also worked out the power supply was under rated for the power amp and replaced it with a supply with 3 times the wattage.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Amplifier static
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
