Author Topic: amplifying this circuit to normal audio amplifier levels?  (Read 4969 times)
Offline dentakuTopic starter
« on: June 02, 2014, 09:19:06 pm »
What would be the least parts heavy way to amplify the output of this circuit to a reasonable level that you could plug into an audio amplifier like around 2 Vpp?
Offline kaindub
Re: amplifying this circuit to normal audio amplifier levels?
« Reply #1 on: June 03, 2014, 02:12:31 am »
Low power - fet amp (fet, capacitor, 2 resistors)
Op amp - non inverting (op amp, 2 resistors, capacitor. Additional 2 resistors and a capacitor if you only have a single sided supply)
Robert
Offline Richard Crowley
  • KJ7YLK
« Reply #2 on: June 03, 2014, 02:52:24 am »
What is the source of that waveform?  If it is being generated/synthesized, why is it such a low level?
What kind of power do you have already available?  (i.e. what is powering the source of that waveform)?
What exactly is the destination?  What is the destination impedance?
Does it REALLY need 2V peak-to-peak? Ordinary "consumer line-level" is 0.7V.
What are the requirements for quality/fidelity (distortion, etc.)?  Is this just a "noisemaker"? (i.e. siren, etc.)
What is the waveform?  Sine? Saw? Triangle?. Clearly, the envelope is triangle, but we can't see the waveform in your illustration.
« Reply #3 on: June 03, 2014, 03:44:42 pm »
The source of the waveform? It's just the output of that circuit. I changed the values of some of the components from the circuit W2AEW built in this video about measuring unknown inductors.
https://www.youtube.com/watch?feature=player_detailpage&v=74fz9iwZ_sM#t=454
I'm just planning to use two 9V batteries to power it.
I'm not sure about the destination or impedance. I'm just hoping to plug it into something that will allow me to hear it like the mic input of my old computer.
That's true. I'm fine with something around 1V. It's not terribly important as long as it doesn't clip and distort.
Yup, it's pretty much just an experimental noise maker. Think of it as a voice from a drum machine or something. It's receives a pulse at it's input and puts out a DING sound.
It's a sine like you can see in W2AEW's video. It's a ringing tank circuit.
I'm attaching a .wav file of the output of the simulation.
  • KJ7YLK
« Reply #4 on: June 03, 2014, 04:33:52 pm »
"That circuit" shows a "black box" signal generator.  That is not a complete circuit diagram.
That video is about radio frequencies. (2.x MHz) Several orders of magnitude too high for anybody (even bats or insects) to hear.
You will never hear that signal no matter how much you amplify it.  What frequency does YOUR circuit output?
Then you're not doing it right.  With a power source of 18V you should be able to easily generate a 2 volt signal directly.
You should be able to take the signal you have right now and feed it into the MICROPHONE input of your computer.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: June 03, 2014, 05:01:31 pm »
Change C1 ~= C2 and adjust the calculation accordingly.
Also, if you're just looking for zero crossings, use a comparator.  No need for audio frequencies then.
Note that the circuit shown merely goes "thud" if the capacitor or inductor have more than 0.5 ohms or so ESR or DCR (enter real numbers for these parameters and see how it simulates).
Seven Transistor Labs, LLC
« Reply #6 on: June 03, 2014, 06:24:35 pm »
I know that he was working in the MHz range. I'm just wondering if it's one of those things that you can simulate in software but is completely impossible in real life with the component values I chose at the frequencies I would like?
As you can hear from the .wav attachment in my previous post, it's well within audio range.
LTSpice tells me it's ringing at 2.32861KHz.
Again, it's just an experiment. I've never used an inductor in anything and just liked the waveform I saw in the video and wondered if it would be possible to use it (modified for lower frequencies) to make interesting sounds.
The "black box" is just putting out a 2Hz square wave that goes from 0V to 4.5V. On every rising edge it triggers a "bing" sound.
« Reply #7 on: June 03, 2014, 07:03:24 pm »
Yeah you're right. I just simulated it with both capacitors at 100uF and the levels are well within useable audio levels.
I just chose real components from the list in LTSpice instead of just generic C and L and using real capacitors models still works but when I change the inductor to a real named model with included Peak Current, Series Resistance and Parallel Resistance numbers I just get little tick sounds instead of a ding.
What I'm guessing from reading your answer is that in real life this won't work? :)
The image I'm attaching shows the simulation using an inductor with realistic values and the one of the right uses the generic unknown un-named 47uF inductor model.
One goes tick and the other goes ding.
« Reply #8 on: June 03, 2014, 07:04:13 pm »
The "black box" is just putting out a 2Hz square wave that goes from 0V to 4.5V. It triggers the "ding" sound.
Online T3sl4co1l
« Reply #9 on: June 03, 2014, 07:23:10 pm »
Oops, I wrote "audio frequency" when I meant to say "audio level"...
Anyway, yet more good reasons why these things are done with op-amps.  (BTW, also check out the peak current through the source.  Got a power amplifier that can do that?)
So you're looking at synth sounds, like bells?  Plenty of circuits out there -- give 'em a look!
« Reply #10 on: June 03, 2014, 10:11:07 pm »
I was just curious if it was practical in real life.
If I plot current of the PULSE source at 4.5V I get these spikes that go from +/-200A :) Is that what you mean by "peak current through the source"?
At 0.1V it spikes to around 4.5A.
Any time I see stuff that oscillates I always wonder if it could be used somehow to make sounds... like any synth geek would.
« Last Edit: June 03, 2014, 10:42:26 pm by dentaku »
