Hi!
I've built a simple R2R DAC using resistors, a rail-to-rail opamp and some logic. So far it's been working well on a single supply, but I want to improve upon the design by adding dedicated positive and negative power rails for the analog part of the circuit. I'm re-spinning the board and this time I also want to incorporate separate analog and digital grounds, as well as the analog split supply. I've added a simplified schematic that might help the following two questions I have:
1. Should the first resistor of the R2R ladder (R9 in my picture) be connected to digital ground or analog ground?
2. Should I connect the analog and digital grounds, and if yes, where? At the power supply (DP831A), or should the GND plane and AGND plane be connected somewhere?
Please see the attachment I included for a full understanding of the context.
Cheers,
Dave Misbehave
EDIT: R13 should be 10k (copy/paste error)! Thanks for pointing it out, nitro2k01!
