No easy way to double the DC output, but if they are cheap enough you could connect two in series and drive the 24V preamp from the connection between the two devices.
I have a severe prejudice against using switching power supplies on low-noise analog circuits such as microphone preamps. It is possible to filter the switching garbage from the outputs, but that is a separate project that needs careful attention.
