That's a voltage amplifier with limited drive. It would need to be followed by a buffer, and in fact because it can't be used as a buffer it shouldn't really be thought of as an op amp. It will be grossly non-linear without feedback. To understand op amps you need to understand amplifiers in general, which is a big topic not easily explained here... I'd recommend the first few chapters of Bob Cordell's "Designing Audio Amplifiers"; all the basic concepts of loop gain, gain bandwidth, bode plots, details like long-tailed pairs, current sources, biasing, transconductance stages, transimpedance stages, compensation, etc is all the same no matter what.
