I did search and poke around as best I could, but I didn't quite see a thread that satisfied. If there is an old non-stuck thread that covers this, please point me there.
I have a recent AAS in Electronics and Computer Technology (plus other degrees, yada yada) so I have some idea what I'm doing. I didn't know that much about scopes 3 weeks ago, but I've learned a lot and understand most of it. I've recently acquired a Tek 2336 100MHz (dual trace?) scope, and am looking for probes to go along with it. The manual lists part number 010 6108 03 as the appropriate probe, which I'm guessing would be the Tek P6108A 03 probe (right?). [Whoops,
new information says I'm wrong, its the P6108 with no suffix.]
According to Tek, there is no modern analogue for that discontinued probe. The same Tek guide says the suggested replacement is P6105A - also discontinued with no modern analogue.
So, a few questions:
Should I try to match the specs (13pF input C) of the original probe? Will any quality 10x probe do - so long as it compensates for the scope's 20pF input?
Should I defer to Tek models?
(The part you've been dreading) Is there a recommended list for probes?
Can anyone point me to the equation for system (scope + probe) bandwidth?
I understand its different for passive and active probes.
Thanks for your time.
Edit: Through sheer dumb luck I've located a (010 6108 03) P6108 probe (eBay). Pictures show it with and without the 10x wire on the BNC, so I assume I'll get the 'without' version.
However, I reckon there's a chance of it being a DOA probe, so my questions stand.
