Is this a receiver only or a transceiver? If it is a receiver only, it won't be so critical, if it is a transceiver, it is better to electrically match the antenna to the transceiver as that will keep the VSWR and reflected power at a minimum. Even if it is just a receiver, I agree with IanB and do your best to get as close as possible. It will hone your construction and problem solving skills.
