1N542 = Ge point contact diode, 45V 10mA.
I'm going to dissent from popular opinion, because the coils on top have far too many turns to be an FM detector stage (typically done at 10.7MHz). And there are far too many coils and diodes for this to be just an FM IF/detector module.
The lower coils might be consistent with a ~45MHz TV IF stage, in which case the one diode (unmarked) should be detecting that, and the 4.5MHz audio carrier will be present in that detector output, which is tapped off by the top pair, and immediately detected.
So I think it's from a classic TV, probably 50s-60s era.
