If the max rms current of your welding transformer is 26Arms, The max rms current of each scr is 26/1.41 = 18.44A (conducting only half wave)
TO220 pack is too weak for such a high rms current: terminals are 0.5mm thick and 0.75mm wide, this is only 0.375mm².
This mean a current density of 18.44/0.375 = 49.17A/mm²...This is very high...to compare, we use 4 to 5.5A/mm² in transformers.
Better to choose a TO247 or a TO3P pack.
Ta: must be at least 65° for convection cooling and 45° with force cooling because your heatsinks are connected with mains voltage and MUST be protected in a housing.
Tj = 120°: ok
Pg: ok...NB: with this duty cycle, it hardly happen to exceed the max gate power.
