It is not able to limit instant peak current.
No need of a current sense, it is useless.
Nope, current sense is needed, and no need to limit transient current, but I've in this calibrated custom Hall sensor current limit set to 16A (avaregae of 10ms 10kHz sampling moving average-half period of 50Hz mains) on welder transformer primary which at 230VAc means 3.7kW, so it will not protect against short circuit, but when welding current will be inceased by potentiometer, safe level phase shift can be easy set, while this thing will turn off in current zero crossing for a few seconds when such overpower event happends.
Without current sensor you have no idea what this phase shift limit can be...until you make blackout in house, trying to find this point with potentiometer
Another story is adaptive phase shift adjustments to rising input power (current). I will test those 1ms time phase shifts adjustments, hoping that below current limit set to 20A per 10ms half 50Hz period it will not create horrible waveforms, due to this phase shift fine tunning
Update: Tested overcurrent protection software set to 3A with this 21W light bulb powered from DC 12V, so multimeter showd 1.63A current draw.
However, when 10ms averaging perido was set.... yep inruch current when cold light bulb was turned on trigered this current threshold of couse
Than changed this time to ~0.1s (1000 averaged current samples) and it was enougth time to warm up bulb filnament to the point, average current sampled at 10kHz within 0.1s from cold start was below 3A overvoltage protection
later, I've connected 55W car lights bulb and of course overcurrent worked all the time, since multimeter showed ~4.44 A current draw
This experiment showed, that probably 0.1s might be fine during welding too, since I'll add also soft start (it will be used in spot welder in the same trafo) and maybe demagnetization of trafo core (in spotwelder where we have short circuit on secondary from th ebegining to the end).
Classic welding is slightly different, but I think it will be nice have primary nominal current set potentiometer, and in software automatically overwoltage current will be set based on those settings as lets say 25% higher-it turns off wedling for 10 seconds when something like this happends-enougth time to cut glued weld electrode from steel plate
Now, calibrated this my new Hall effect sensor and upgrading software to implement this adaptive phase shift controll-overcurrent (overpower) protection is already done and testing this right now, while preparing to myth buster of crimped soldered connectors vs only crimped
BTW: Mag amp on this welder transformer primary in on my todo list-I have to upgrade MOT iron core with two windings and add thin contoll coil in the middle-It will be interesting to see if it works
