This is a really basic question!
I have an arcade table I am restoring and planning to replace the control PCB with a FPGA based solution. The FPGA has many 3V3 i/o pins which are not 5V compatible.
Previously the PCB operated (primarily) at 5V so the wiring to the buttons was that the button was grounded on one side and then the other side came back to a wire that ended up on the PCB at a 8255 (Intel old style Peripheral Interface) with 1kR pull-up and a 220R current limiting resistor.
I'm planning on using a trio SN74HC165 to provide sufficient lines for the buttons... just wondering if I could get away with operating at 3V3 or I should operate the shift registers and buttons at 5V and level shift back down to 3V3?
The total round trip distance to the furthest button is around 150cm
What do I need to consider? R of wire, immunity to noise?
