i just spent 15min hooking up a 2x16 display but the potentionmeter for the contrast isnt working.Datasheet for display ( http://www.taydaelectronics.com/datasheets/A-1748.pdf )this is how i have it hooked up:Pin 1 to Arduino GNDPin 2 to Arduino 5VPin 3 to middle pin of the 10k potentiometerPin 4 to Arduino pin 12Pin 5 to Arduino GNDPin 6 to Arduino pin 11Pin 11 to Arduino pin 5Pin 12 to Arduino pin 4Pin 13 to Arduino pin 3Pin 14 to Arduino pin 2Pin 15 to Arduino 5VPin 16 to Arduino GNDis this wrong or is something just not working. and is it bad to just not use the pot because it seems to works fine without it
The data sheet has the pot as 0-20k, some displays the contrast adjustment is really only at one end of the range or the other. Might be worth adding in a 10k resistor in series between +5v and the POT and see if it makes a difference?
The extended temperature range displays often require a negative voltage on the contrast pin. Even the standard ones require a voltage close to 0v, so you don't tend to get much usable range on a pot wired between Vdd and 0v.
Looks like it needs about -0.93V on the contrast pin! (Annoying, since nothing else in the project needs a negative rail...)
Quote from: mikerj on January 24, 2016, 01:35:08 pmThe extended temperature range displays often require a negative voltage on the contrast pin. Even the standard ones require a voltage close to 0v, so you don't tend to get much usable range on a pot wired between Vdd and 0v.Thanks for this tip! It solved the same problem I'd been having with a large-digit 1602 module. Looks like it needs about -0.93V on the contrast pin! (Annoying, since nothing else in the project needs a negative rail...)
