Avoid the DHT11,
their indications are close to none.
I have recently bought 10 DHT12 which are supposed to be an improved version, but which in fact differ from the DHT11 only by the interface.
After some preliminary testings, I have set up a more complete experiment with 9 sensors at the same time.
They give answers that are extremely different for the humidity. Not at all within the advertised specs of the maker (AOSONG) which says 5% for the DHT11 (did not find the DHT12 datasheet)
The temp seems OK, but
I got 48%, 52%, 56%, 59%, 61%, 68%, 69%, 72%, 72% for the Humidity output
so a max difference of 24% which is huge.
A same experiment with 5 DHT22 gave much better results
DHT22
Hum: 63.20 % 60.50 % 63.30 % 65.30 % 66.20 % Temp: 24.60 C 23.70 C 23.40 C 22.90 C 23.10 C
Hum: 63.20 % 60.50 % 63.30 % 65.30 % 66.30 % Temp: 24.60 C 23.70 C 23.40 C 22.90 C 23.10 C
Hum: 63.30 % 60.50 % 63.30 % 65.30 % 66.30 % Temp: 24.70 C 23.70 C 23.40 C 22.90 C 23.10 C
