>Do you plan to power the Arduino with the LiPo charged by the TP4056?
I'm just trying to power a pro mini 3.3v with a lipo battery, put everything inside a super small case, but keeping the possibility to program and charge without opening the case.
What I don't like in my current implementation is the need for the 2 usb ports, it's bulky when the 2 usb cables are connected, and mechanically problematic: I need to drill 2 holes and fix solidly the arduino and the TP4056 to the case. 2 points of failure. In addition, I cannot place the TP4056 where I want inside the case since the usb port dictate the orientation and position (touching the walls)...
>Are you using the Arduino to work with the TP4056 to help it handle charging, show voltage, current, etc?
No, the TP4056 will just charge the lipo when the external usb is connected.
>Which Arduino are you using?
A pro mini 3.3v, but I may switch to a wemos D1 mini (esp8266) later. Not sure.
