Author Topic: Arduino Nano vs Mini Pro  (Read 19252 times)
Offline nbrittonTopic starter
« on: November 01, 2015, 05:10:08 am »
I want to pickup some extra spare arudinos to use in dedicated projects. On Aliexpress, I can pickup 10 nano clones for $21 or 10 mini pro clones for $16.90, which ones should I get?
Mini Pro: http://www.aliexpress.com/item/Free-Shipping-1pcs-lot-ATMEGA328P-Pro-Mini-328-Mini-ATMEGA328-5V-16MHz-for-Arduino/32340811597.html
Nano: http://www.aliexpress.com/item/Freeshipping-Nano-3-0-controller-compatible-for-arduino-nano-CH340-USB-driver-NO-CABLE/32341832857.html
Uno: http://www.aliexpress.com/item/1PCS-Tower-Pro-9g-micro-servo-for-airplane-aeroplane-6CH-rc-helcopter-kds-esky-align-helicopter/32340815424.html
Even the UNO clone is only $2.74, how come I can't find a bare Atmel ATmega328P chips for as cheap as these assembled boards on aliexpress?
Offline crispy_tofu
Re: Arduino Nano vs Mini Pro
« Reply #1 on: November 01, 2015, 05:22:17 am »
The Atmel site lists the TQFP ATmega328P chips as USD 1.79 (in 1000s), so they're nearly definitely using fakes  :-+
But what I really want to know is what this means:
Offline LukeW
« Reply #2 on: November 01, 2015, 05:45:12 am »
#1 has no on-board USB connectivity, so you need to provide your own FTDI cable or similar serial device. http://www.freetronics.com.au/products/usb-serial-adapter#.VjWmHt94vTE
#2 has USB on board, but you'll need to provide a mini-USB cable yourself. (And these days that's probably the least common of the USB connector standards.)
#3 is a full-size Arduino-equivalent form factor, which may be a disadvantage (or an advantage) for you depending on what you actually want.
Both #2 and #3 will almost certainly use something like a CH340 cheap Chinese USB virtual UART, so you'll need to set up appropriate drivers for that on your PC, and easy "plug and play" use may not be something you can take for granted. You may be OK but it depends on your OS.
As far as AliExpress supply of cheap ATmega328 silicon (or clones) is concerned, sure you can get them. Caveat emptor of course, as always with these things.
http://www.aliexpress.com/item/Free-Shipping-10PCS-LOT-atmega328p-au-atmega328p-atmega328-QFP32-In-stock-Best-price-High-quality-Hot/32352260821.html?spm=2114.031010208.3.9.P2hWnr&ws_ab_test=searchweb201556_3_71_72_73_74_75,searchweb0_0,searchweb201560_9
« Reply #3 on: November 01, 2015, 06:20:29 am »
If they are fakes, will they work the same as real Atmel chips?
« Last Edit: November 01, 2015, 08:05:27 am by nbritton »
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: November 01, 2015, 09:47:59 am »
mini doesnt have usb chip. nano has china ch340G usb chip. i quickly tested the $3 nano it seems to take the code, havent done timing or extensive test if its a couterfeit... i havent test my newly arrived <$3 mini if its a counterfeit as well.. if you dont have avrisp programmer or usb->uart chip, forget mini...
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: November 01, 2015, 11:34:30 am »
Unlikely to be fake, just "not entirely legimatly sourced", probably actual atmel silicon inside, but may be over-run from an official order gone out the back door, a ghost shift running the factory during the night, rejected parts for non-critical reasons etc.
It's not impossible there are compativle clones out there, but if so, they woul have to be very good ones because I have never heard of anybody finding something that should work didn't on thier china-sourced atmega.
Offline GreyWoolfe
  • NW0LF
« Reply #6 on: November 01, 2015, 01:35:13 pm »
I bought a couple of these from fleabay: http://www.ebay.com/itm/111739530679?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
$6.49 USD is more than you paid but my windows 7 laptop loaded it up without any issues or need to download drivers and when I upgraded to windows 10, it still worked perfectly.  No issues with the Arduino software either.  I would buy these again if I had a need for any more Unos.
Offline amyk
« Reply #7 on: November 01, 2015, 02:49:54 pm »
1ku is not a lot for mass production applications like these. I expect these were bought in an order of magnitude or more quantity, and there are significant discounts at that level.
« Reply #8 on: November 01, 2015, 06:20:54 pm »
Well it says they have 50k in stock, so that is considerably more than 1k. I think I'm going to take my chances, the reviews are good for the product and company and they have 7,500 pervious orders between the three of those devices. All I care is that they run code, I already own three legit UNO R3s for development purposes. What programming method is recommend for the Mini Pros?
« Reply #9 on: November 01, 2015, 08:29:59 pm »
Does the CH340 USB to serial interface have adequate support on Mac and Linux? I know that WCH has a driver here: http://www.wch.cn/download/CH341SER_MAC_ZIP.html but does it still work with current versions of Mac OS X and is it hassle free to install and use? Is FTDI supported by default without installing anything? What is supported out of the box without any special drivers?
« Reply #10 on: November 01, 2015, 09:05:13 pm »
If I buy enough of these can I use them to duplicate the discrete circuity of a 1970s era computer? I would like to make my own computer from scratch so that I can learn more about how computers work. If I go the FPGA route then I can't probe its internals, so I was thinking a handful of arduinos would make a better learning rig. Do you know of any pre-made trainer kits that would be a better learning tool?
« Last Edit: November 01, 2015, 09:20:30 pm by nbritton »
« Reply #11 on: November 01, 2015, 09:43:34 pm »
Can the HC-06 Bluetooth to RS232 module be used to program the Mini Pro? I think I'm sold on the Mini Pros if I can program them wirelessly.
http://www.aliexpress.com/store/product/hc-06-HC-06-RF-Wireless-Bluetooth-Transceiver-Slave-Module-RS232-TTL-to-UART-converter-and/731260_32342784842.html
Offline retrolefty
« Reply #12 on: November 02, 2015, 03:17:53 am »
 Remote programming of a typical arduino board requires the ability to pass the DTR signal from PC via Bluetooth to the arduino. The only proven Bluetooth solution I've found is the Adafruit EZ-link module. While it does cost more then most Asia BT modules it is a proven plug and play serial transparent and auto-baudrate (with windows 10 at least) and seems very reliable up to about 40 feet. Uploading takes longer then USB as the DTR stuff takes some time but it does allow remote programming which can be a very cool function for some projects.
http://www.adafruit.com/products/1588
Offline tec5c
« Reply #13 on: November 02, 2015, 04:09:45 am »
Yes, a textbook on computer architecture.
« Reply #14 on: November 02, 2015, 04:19:50 am »
Ugh... I have dyslexia, so reading a book is not easy for me. You have videos instead?
Online Mechatrommer
  • Country: my
« Reply #15 on: November 02, 2015, 06:28:56 am »
good luck and hava nice days...
http://www.waitingforfriday.com/index.php/4-Bit_Computer
Offline zapta
« Reply #16 on: November 02, 2015, 04:07:39 pm »
FTDI runs on Mac and Linux without having to install drivers.
I avoid installing drivers and other software that come from China, mostly for security concerns.
Offline edavid
« Reply #17 on: November 02, 2015, 05:33:58 pm »
Nano.   It's worth the little bit of extra money to get the USB port built in.
Maybe you're not very good at searching  :)
http://www.aliexpress.com/item/Free-Shipping-10PCS-ATMEGA328P-AU-ATMEGA328P-ATMEGA328-8-bit-microcontroller-AVR-32-k-flash-memory-QFP/32510774853.html
Except that no one has ever seen an AVR clone  :-//
Does everyone see the irony here?  #ftdigate
« Last Edit: November 02, 2015, 05:45:04 pm by edavid »
Offline tszaboo
« Reply #18 on: November 02, 2015, 05:46:14 pm »
https://olimex.wordpress.com/2013/12/12/3-arduino-possible-holly-molly-chinese-avr-clones-are-coming-meet-lgt8f88a-mavr-core-processor/
So core is copied, the rest is just putting peripherals next to each other.
Offline edavid
« Reply #19 on: November 02, 2015, 05:47:55 pm »
Notice that post is from 2013, and it still hasn't happened.
Offline Cliff Matthews
    • General Repair and Support
Offline edavid
« Reply #21 on: November 02, 2015, 06:31:29 pm »
Maybe it has.. http://www.newegg.com/Product/Product.aspx?Item=9SIA86V2Z33190
Interesting, but it's a 2013 product, with only 8K flash/1K RAM, and it costs more than an Atmel ATMEGA328 based board.  Is the LGT8F88A pin compatible with any Atmel chip?
Offline tszaboo
« Reply #22 on: November 03, 2015, 01:41:57 pm »
How much effort does it take to put extra flash into a microcontroller, and to laser mark a different company's name on it? The price of that particular board is not indicative.
The real issue is that chinese companies have no moral code, when it comes to copying and they will guard their internal market and information to their last breath.
Offline paf
« Reply #23 on: November 03, 2015, 04:08:03 pm »
One "minor" detail.
Minis and Nanos do not have a polyfuse. So, if the "part between the chair and the breadboard" makes a short circuit, on Nanos you will have to replace an SMD diode (minimum).
You can get cheap "Arduino Uno" clones from China with a polyfuse, offering some protection from shorts.
Ebay examples:
http://www.ebay.com/itm/NEW-UNO-R3-ATmega328P-CH340-Mini-USB-Board-for-Compatible-Arduino-/311155383820?hash=item48724e5e0c
http://www.ebay.com/itm/UNO-R3-ATmega328P-CH340-Mini-USB-Board-Compatible-Arduino-NEW-/221591186520?hash=item3397dd2c58
Another warning: While on the real Arduino Uno, the USB 'converter' may be programmed to "look like" a keyboard/mouse/joystick to the host PC, the CH340g device is only a serial port.
Offline edavid
« Reply #24 on: November 03, 2015, 04:44:04 pm »
One "minor" detail.
He said he wants them for embedded projects, so presumably the smaller size would be more important.  Development can be done with an Uno clone though.
I think you are mixing up Unos and Leonardos here.  Leonardo clones are available also, but I haven't seen them in the smaller Nano-like size.
Offline paf
« Reply #25 on: November 03, 2015, 05:45:36 pm »
Good point.
Unos can be used as keyboards also:
http://mitchtech.net/arduino-usb-hid-keyboard/
Leonardo clones exist (at least on eBay) and they seem to have a polyfuse:
http://www.ebay.com/itm/Leonardo-Pro-Micro-ATmega32U4-16MHz-5V-Replace-ATmega328-Arduino-Pro-Mini/321516943415
Offline MLXXXp
« Reply #26 on: November 03, 2015, 06:12:47 pm »
The Arduino/Genuino Micro is essentially a Leonardo in a smaller form factor. Ebay clones are available (these are the longer ones with the reset switch). The shorter Sparkfun Pro Micro is also similar to a Leonardo but lacks some I/O pins and other signals, along with the reset switch, 3.3V output and ICSP header, but is available in a 3.3V/8MHz version (clones too).
« Last Edit: November 03, 2015, 06:21:46 pm by MLXXXp »
Offline edavid
« Reply #27 on: November 03, 2015, 06:46:23 pm »
Thanks, they are also available on AliExpress for about $3.
I guess another option would be a Digispark clone @ $1.50, but they don't have much code space.
« Reply #28 on: November 03, 2015, 09:54:21 pm »
Even with the CH340 USB to serial chip? I use predominantly Mac and Linux, my only Windows PC is my work issued laptop in my drawer that I never use.
What about a through hole chip?
Offline edavid
« Reply #29 on: November 04, 2015, 12:21:25 am »
There are drivers available for Mac and Linux, and some people seem happy with them, e.g.: http://0xcf.com/2015/03/13/chinese-arduinos-with-ch340-ch341-serial-usb-chip-on-os-x-yosemite/
http://www.aliexpress.com/w/wholesale-atmega328p%25252dpu-10pcs.html?site=glo&SearchText=atmega328p-pu+10pcs&g=y&SortType=price_asc&groupsort=1
« Last Edit: November 04, 2015, 04:57:22 am by edavid »
Offline dadler
« Reply #30 on: November 04, 2015, 03:38:06 am »
If you intend to make your own boards at home, it's so much easier to use SMT parts. It's such a pain to have to drill TH holes...
The larger SMT parts (0805, SOIC, QFP32) are in some ways easier and faster to solder by hand as well (don't have to flip the board over, etc), even if you are sending out for boards.
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
« Reply #31 on: November 06, 2015, 11:15:28 pm »
I have bought Mini Pro and Nanos by the pound (mostly from Deal Extreme) over the last few years. All of them worked as expected. The 328s themselves aren't fakes, since they worked as expected.
The only problem I had were with a few of the Nanos v3.0 that still had the fake FTDI chips (anyone remember the "FTDIgate" ?). the fake FTDI chips wouldn't  last as much and would fail after only a few hours. This didn't trash the boards entirely, because I still could program them using ICSP, bypassing the bootloader, meaning the 328s on them were still perfect. I didn't have this problem with the Nanos that feature the CH340 USB bridge.
I am more inclined to buy assembled Nanos and Mini Pros from China than spare Atmega328 in QFP32: when buying spare chips, these are much likely to be fake, and even Sparkfun has been a victim of fake 328s: https://www.sparkfun.com/news/350
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline Phili76
« Reply #32 on: November 18, 2015, 07:31:27 am »
To use the CH340 on OSX El Capitain you have to turn off kext driver signing. It´s working but you have to disable driver signing. Maybe there will be a driver someday on the official site.
Just found: http://blog.sengotta.net/signed-mac-os-driver-for-winchiphead-ch340-serial-bridge/
Offline paf
« Reply #33 on: November 19, 2015, 10:12:11 am »
Did you try to repair them?
FTDI clone repair:
http://arduinotronics.blogspot.dk/2014/10/does-windows-ftdi-update-brick-your.html
Fixing the FTDI drivers – prevent auto updates
http://www.rei-labs.net/fixing-the-ftdi-drivers-prevent-auto-updates/
[Guide] Permanently repair broken fake FTDI chip
http://forum.arduino.cc/index.php?topic=274387.0
FTDI Bricked Chips Fix
http://tech.scargill.net/ftdi-bricked-chips-fix
Offline AlxDroidDev
  • Country: br
« Reply #34 on: November 19, 2015, 10:53:10 am »
Oh, yes, I did! I tried all of that. Somehow the FTDI on them went FUBAR, which makes me believe that not only the fake FTDIs are susceptible to the "FTDIgate" bricking problem, but they also have a very shorter lifespan.
