I am working on a project using a TI ADS1220 24bit ADC and have the voltage output sent to the serial monitor. This seems to work fine (the voltage measurements are quite accurate compared to my 34401A) but after a few minutes it will keep updating but the value will be stuck (i.e instead of small changes due to noise the exact same value is repeated). The time that is required before it goes into this timeout seems to vary. It is interfaced over SPI, I'm not sure what would cause something like this. Any ideas?
