I haven't blown up anything yet . . . (but I'm trying . . .)
My background (if it helps):
General class HAM (36years) and worked with EE's for 14 years (but I was Software Programmer, not "electrical" oriented). So, I'm not a complete electrical/eletronic idiot. I AM, without question . . . a complete Oscilloscope Newbie/Idiot.
I wanted to do some things with Arduino's and would be using Sound (and/or Piezo's) and thought I'd need something more than just a DVM to see the waveforms and levels involved. So purchased an OWON SDS7102.
I understand "floating/different" grounds. (I've seen them in those 14 years of R&D work, and have seen the famous touching the guitar/microphone knocked on your butt examples.)
And I watched on Youtube: EEVblog #279 - How NOT To Blow Up Your Oscilloscope!
(Excellent video.)
Understood everything in the video. And yet, a problem/question still remains.
The question (finally):
When I hookup the Arduino to the 9v wallwart, I can use the oscilloscope to measure voltages.
When I hookup the Arduino to my PC (powered by an APC UPS if that matters) through the USB cable . . . and hookup the Oscilloscope Ground lead to the GND pin on the Arduino . . . the Arduino loses power and resets.
Didn't hurt the scope (Owon SDS7102), didn't hurt (or reboot) the PC. (Though the PC does "beep" the loss/regain of the Arduino visibility via USB as the Arduino resets.)
I understand from the EEVBlog youtube video . . . this would happen if I connected the scope ground lead to say . . . 5+ on the Arduino. (It has a path to loop back through the PC to the scope plugged to Earth Ground, and I'm shorting out 5+ to Ground.)
But . . . I'm 1000% certain, I was hooking the scope ground lead to GND (black side header) on the Arduino.
What's going on?
Is the GND (on the black Arduino side headers) somehow "not" the same as the Ground . . . coming in through the USB port?
Or . . . is the APC UPS isolation getting me?
I understand from the video, if I had hooked scope ground to "the wrong point" on the Arduino . . . bad things would happen. But, it sure seems, that the Arduino GND was "the right point".
Again. . . when I plug in the 9V wallwart . . . everything works. (Still clipping the scope on the same side black GND header.)
Were I at home . . . I could try it again, and put a DVM between scope ground lead and Arduino GND to see what the difference is, but that will have to wait.
What am I missing?
Thanks,
jkh
