You should consider that the average current through the strip is half of the maximum current, since it branching off every now and then. Also, powering it from both ends will give you 1/4 of the total current. I would suggest to measure the resistance of the strip GND, between both ends. I'll do the same, I have a "dumb" RGB strip.
I also noticed, that with the supplied controller, the duty cycle was never 100%.
I started calculating at some point, that it would be good practice, to create a DC-DC stepdown converter, very small size, maybe even integrated inductor in some SO8 package, with preset voltage output, and minimal passives. That would reduce cabling cost and make addressable LED strips easier to install. And place this DC-DC on each section. Like connect 12/24V on one input, you are done, voltage drop doesnt matter. But solution cost was too much.
mod: I see someone aready measured it.
