By dangerous mean if I touched both terminals when it is fully charged. Also is there any project ideas with these capacitors you can think of. Thanks rich
There was a test on youtube done on this, anything below 40v DC was okay, above that to 50v was painful, and anything past that dangerous. that was a constant current too. so a 2.5v might be like a static pop but nothing that will hurt you.
now i have a 600V cap 500uf, that will probally stop a heart. but not that i am willing to ever try that. also have several 400v caps that i rescued from a dumpster, i gave them a lovely home on my parts shelf, they are comfy, and well taken care of, those poor caps were just left out in the cold..poor poor stray caps.
No,2.5 volts will feel like nothing at all!
The
current capacity of a device or circuit has no effect upon the current
through you it can cause,if the voltage is insufficient to produce a dangerous,or sometimes,even a perceptible,current.----Ohm's Law again!
Voltage is the determining factor.
*Touch both terminals of a fully charged 12v car battery (a device with a massive current capacity) on a cool,dry day,& it will feel exactly like a
fully discharged car battery on a cool,dry day.
If it is hot,& you are sweating,12v will give you a very slight stinging sensation,if you contact both terminals with a sweaty part of your body--most commonly your forearm.
*Sort of,but not quite an exception!
In some circumstances a high voltage supply designed to operate with an extremely low current draw,may have such poor voltage regulation that you will get an initial "zap" falling off rapidly to nothing.
It is always best to assume that WON'T happen!
