Your multimeter is probably not sensitive enough to measure such low capacitance or maybe the capacitors are faulty (open)
If they're really capacitors, one of the numbers is capacitance, the other is voltage. Could be 68
pF 470v and 47
pF 750v rated capacitors. But 470v and 750v are really big numbers, kind of hard to believe it.
It could be that the numbers are written using the convention that the last digit represents the number of zeroes so then 470 becomes 47 x 10^0 = 47x1 = 47 and 750 becomes 75 x 10^0 = 75v.... but it's just a guess.
The J says tolerance +/-5% .. see
http://wiki.xtronics.com/index.php/Capacitor_Codes , table 2.
edited to say picoFarads (pF), not nanoFarads (nF).
