Hi all, forum newbie here
This question is directed to fellow AoE 3 owners. I won't include a picture as I am concerned with copyright
My question is about
(b) in
Exercise 2.24 (page 125): a transistor current source with a voltage divider at the base to provide DC bias and an emitter resistor to "set" the current.
The authors write that as the transistor's β varies from 50 to 100 over the full compliance voltage range, the output current will vary, which is caused by two effects.
The first effect should be the β variation changing the load on the voltage divider at the transistor's base. Now I reckon the second effect is the
Early effect (V
BE varies with V
CE edit: at constant IC). What confuses me though is that they specifically ask how the Early effect influences the output current in
(c). It doesn't really make sense to me to ask for something in one question and have the answer for it right there in the next question.
Am I missing something here?
