Technically, AC vs. DC does matter to the problem -- we must account for skin effect, because we haven't been told to ignore any part of real physics, and we have a real physical setup here, including material properties (the cable is specified as copper!).
Effectively, it's a pipe with a wall thickness of maybe half an inch, at AC! This increases a) and decreases b) by about tenfold.
The result for c) will change in an interesting way: the outer layer becomes vaporized, while the core remains cold. It will "burn" from the outside in.
Actually, an even better question that follows: how long will it take to blow out this "fuse wire"? Can it even reach full current (assuming DC now) before the conductor is completely exploded?
The reason is this:
Any path has inductance. If we apply 115V DC to a conductor, say in a few microseconds (easily enough achieved, say with an explosively actuated switch -- since to be fair, we have to move a lot of metal quickly, to get a connection that's as solid as the cable it goes between), then the current will ramp up linearly after that time. Say the conductor is 10 meters long. The inductance of free space is ~1.257 uH/m, and there is a geometry factor that depends on arrangement, so for simplicity let's say it's 10uH total. This gives a ramp rate of dI/dt = V/L = 115V / 10uH = 11.5 A/us == MA/s. So it will take one second just to reach 115 x 10^6 watts (drawn from the supply).
Speaking of skin depth -- in that time, current will still be diffusing into the conductor (at a depth of a few inches), so the conductor will be heating up quite rapidly indeed!
The same situation at AC, becomes much less interesting: 10uH at 60Hz is 3.7 milliohms, or a paltry 30kA. Such currents are in fact common in real world applications: aluminum smelting. They use arm- or leg-sized busbar, and, I would assume, rectify it as soon as possible after the transformer.
