Greetings EEVblog,
In the modern era, it is common practice among those interested in old video game consoles - the Atari 2600 in this case - to modify the video output to something more convenient. For the record, I still have a few 300 ohm RF CRT sets to use - but my issue and questions stem from observing composite video and s-video output. The Atari 2600 went through numerous revisions when it was manufactured, and my unit here is revision 14 (woodgrain, 4-switch).
TL;DR - I think the custom AV chip ("TIA") is rather sensitive to noise, and I am wondering if feeding it cleaner power would help. And I am wondering how I should best do that.
This story started with something I noticed in this unit with two different video mods - diagonal lines of interference in an otherwise fairly decent video output. The lines run from the top right to the bottom left. At once point I noticed I could rotate them and reduce/increase their thickness if I messed with the power switch. I thought, mistakenly, that my problem might be from the switch - and I then later noticed that I could also alter their orientation and thickness by pushing the cartridge around a bit.
An example of these lines can be seen in the purple at the bottom of the first screen in this video, and in the blue sky during the second part. They are much more pronounced in person -
There seemed to be no change after doing a bit of a refresh (new power jack, 7805, electrolytics, a film cap, etc. - some of which were part of an early 80s service bulletin) as well as trying a different video mod.
At some point between that and : doing a cartridge port reflow, adding a 220uf cap to the 7805 and a 220uf cap + .1uf ceramic to the TIA power->ground, the lines cleared up A LOT. They don't dominate the signal the way they used to. Sometimes, they are barely noticeable.
After talking to another Atari guy, we wondered what might be done with the power feed to the TIA chip (could an inductor in series with the power feed to the chip help, etc.)
So I reviewed "EEVblog #594 - How To Measure Power Supply Ripple & Noise" to double check my settings, did some measuring, and ended up here to get some thoughts.
I am ashamed to admit that I did still use the ground clip from a single probe to do the measurement.
I also noticed a change in the intensity of the power signal when going from one screen to another for the game I had hooked up at the time (used composite video to a PVM monitor - standard 75 Ohm termination)
Open to thoughts and opinions.
