Author Topic: Attach power to vdd or vpp on thermal sensor?  (Read 1843 times)
Offline DucttapeTopic starter
« on: May 16, 2018, 08:56:19 pm »
I have a Grid-Eye 8x8 thermal sensor (AMG8854). Any tutorials I've found using this sensor assume the AdaFruit breakout board (using similar AMG8833). Adafruit labeled their power connection 'VIN'. My Panasonic version of the same chip offers both 'VPP' and 'VDD' connections. What's the difference (i.e. which should I use)? The attached photo shows the Panasonic datasheet info on top and the Adafruit board below.
« Last Edit: May 16, 2018, 09:00:39 pm by Ducttape »
Online rstofer
Re: Attach power to vdd or vpp on thermal sensor?
« Reply #1 on: May 16, 2018, 09:05:06 pm »
You could check the schematic for the Adafruit board or even the datasheet for the sensor.
AFAICT, Vpp isn't used...
Typically, Vpp is used for device programming
The following users thanked this post: Ducttape
Offline Nerull
« Reply #2 on: May 16, 2018, 09:14:03 pm »
https://industrial.panasonic.com/cdbs/www-data/pdf/ADI8000/ADI8000C62.pdf
"Make electrical potential of terminals 9 [VDD] and 13 [VPP] the same."
When you have a question about how a chip should be connected, check the datasheet. You should probably be reading datasheets for any chip you're using anyway.
« Last Edit: May 16, 2018, 09:17:30 pm by Nerull »
Offline floobydust
« Reply #3 on: May 16, 2018, 09:27:33 pm »
AVDD-PC 20R (not R1 200R in your pic)
« Reply #4 on: May 16, 2018, 09:53:37 pm »
My pic is from the Panasonic datasheet. Are you saying there's an error in it?
« Last Edit: May 16, 2018, 10:17:50 pm by Ducttape »
« Reply #5 on: May 16, 2018, 10:05:15 pm »
My pic was taken from the Panasonic datasheet, from Digikey, entitled "Infrared Array Sensor Grid-EYE (AMG8854M01), which doesn't include the circuit diagram in your post. Thanks for the additional info.
