There are quite a few sellers of that exact hot air soldering station. The front panel has different names, but they appear identical.
I just purchased one for 35 USD. I had seen the various notes about poor grounding, switching the neutral instead of the hot power lead, etc. so I went through the unit before I ever even turned it on. They were indeed switching (and fusing) the neutral side of the line connection, so I reversed that. Thankfully the tip is grounded to the case and the ground lug on the power cable, but I still went through and confirmed reliable metal-to-metal connections all the way through (there have been some reports of oversprayed paint insulating the grounds).
The design inside is nothing special, but nothing awful. Single sided PCB (with no silkscreening!) made of what appears to be XXXP (as opposed to FR-4/G10 that most are used to), not too densely packed, reasonable wire lengths (i.e. not stretched too tight), and so on. I've seen much worse.
Afterwards, I powered it up. It works great. Gets hot nice and fast, the reed switch in the handle turns off the heating element (and eventually the fan once things cool down), the temperature adjusts easily, and so forth.
I think what we have here is a decent (read: fine for the price) design, but the quality control is awful. The tradeoff for the great price on a hot air (de)soldering station is that you must invest 30-60 minutes going through it to confirm all is well.
I would spend the money again without hesitation.
