i agree homebrew!!!
but..
If something goes wrong (i.e. due to metal shavings inside the ATX-PSU) you will have a bad time.
i drill the tower, not the atx psu
Check out this thread. Pretty much everyone appreciates compact lab equipment.
a tower has a surface close to the one a lab psu has
it's just higher
According to your logic you could also argue to use a car battery. Then you have some 600A of fault current. So you might stand the change of being blinded by the arc, getting burns, burn down the house, the darn thing may explode due to hydrogen generation and shoot sulfuric acid everywhere etc. etc. etc.you don't care of that 600A of fault current if you do the thing correctly.
dave did his circuit, thinking there was a limiting current part outside.
once you fire something because of that kind of error, you try to don't do it a second time
thinking a lot before doing anything
don't play with blackbox like with lego
" If you claim that these never happen to you, you must be either lying or you just haven't spent enough time behind the bench yet."
i fire some, so i prefer thinking about before acting
how the circuit would work
how much is the impedance input
you don't know?=> blackbox=> lab psu
you don't have? don't touch or limit the current+make some protection before use it
you don't know how to? don't touch it
let the collegue fire it
I didn't quite understand this question. Please elaborate.
thing seem to work correctly on your board, your psu limit current, but the environment is not the same once you leave the board...
what if your collegue didn't put something to limit current..or you forget
or your colegue "short-circuit" some protection( i saw some short circuit fuse because it fire too often....)
you see where i want to go?
you need to limit current, put it on the board, on the same circuit, not outside
my point of view
you need lab psu when your work on a circuit you don't know, can't know, a blackbox
anyway , you're hobbyist (?), you work on your own circuit,you don't play with blackbox
you play sometimes with scavaged part but you HAVE the datasheet
a lab psu give you a second chance to do something wrong
