Ok, I'm planning to build a crossbar switch for a hifi setup. It is a bit more complicated than your run off the mill stereo.
I've got the switches, they're mechanical non-interlocking push-button switches.
Each input channel will be fed by a small op-amp based amp to get signal levels from all sources to the same level.
For the outputs I was thinking I'd feed them into an virtual earth type circuit per channel.
This picture may help to clarify what I plan to do:
Never mind the details, at the moment I'm only interested in the theory.
Let's say there are signals on all three inputs.
If I depress S1 and S4 I get the sum of input 1 + 2 on output 1, so far so good.
But what would happen if I depress S1 and S2? All other switches are off.
Does the signal split between output 1 + 2 evenly? Probably not, right?
Please enlighten me, I've been thinking about this for some time but have not been able to make up my mind.
