I'm trying to design a simple little audio circuit, but there's more to it than meets the eye (at least for me).
I have an audio DAC outputting 2.1 Vrms full-scale and then an amplifier that cannot tolerate such a high signal.
I'm trying to attenuate the signal to around 0.42 Vrms, just using a resistor divider, and a cap to ground (low-pass filter).
Specs:
DAC: Outputs 2.1 Vrms, with 1K source impedance.
Amp: About 55K impedance (I think!), I measured how much it "loads" down my signal and calculated this. Needs 0.42 Vrms.
What do you think, will it work? Will there be any unexpected effects, .e.g. from impedance mismatch?
