Thank you for this video!
What values of frequency, capacitance and inductance did you choose for your demonstration?
When I try to reproduce the results myself, I've found that the phase shift between the two oscilloscope channels varies depending on the frequency of the signal applied. Why would it be anything other than 90 degrees? Watching your video again, I can see that it's not exactly 90 degrees for your test, either. Why is that?
Thanks!
- Ken
