Had the OP done what I suggested in reply #4, we wouldn't be having this discussion.
I carried out the procedure described in reply #4, and now the impedance analyzer sweep is like this:
The capacitance is nearly flat with frequency and equal to 10 uF, although I still see a little bit of the decrease with frequency due to etched foil.
I also got this same result with another one of the caps by applying a 50 volt peak, 60 Hz sine wave from a transformer driven by a variac.
The reformed cap measures 10.7 uF on my Fluke 187 DVM.
So all the OP need do is follow the procedure in reply #4 and all should be well. Simply installing in the CRT equipment and powering it up would probably do the job too. It might take a minute or so to settle down to a final value.
