Wow, thanks for the replies!
Yansi, yes the 750p caps were a mistake in the original schematic. I forgot to change the values.
BrianHG, I'm not married to the 5532 haha!
I was going to prototype it with those since I have a few on hand
Your schematic has poorly filtered inputs. You forgot that the common mode component of the input signal has to be filtered too. And it should be filtered with even more care than the differential mode!
Yeah I was going to get around to the filtering aspect at the end. I usually leave it till the last since the main bit is the amplification/mixing. Of course, it has no common mode rejection in the last op amps which is a giant mistake.
Output impedance of 5534 is NOT 600ohm. It is almost exactly zero at the AF frequencies. You need to add a series resistor to NOT and never load the opamp capacitively (cable capacitance may and will make it unstable if enough of it present).
Doh! I knew I'd missed some resistors. Thanks.
I think you do not need to adjust any gain. Just use standard 1% resistor. These are precise enough for summing L+R channels for a subwoofer.
The gain for my circuit is a requirement because the subwoofer gain only goes from -6dB to +6dB on its input, referenced to its own amplifier inside. The studio monitors have an input swing between -20dB and +6dB referenced to their amplifier. So it's required to have the ability to set the gain between x0.5 (-6.02dB) and x2 (+6.02dB) at least, so I have extra room to play with.
There's a nice book about such audio enginerding from Douglas Self, Small Signal Audio Design. Highly recommend that.
I'll check it out, thanks. I've heard his name mentioned a couple of years back but will definitely give him a read.
EDIT:
Wait a miniute, that's easier. VR1 (a potentiometer simulated as two resistors) alters the output level.
Ahh, the output of the op amp goes into the inverted input of the other. I did that with an RIAA preamp I built a few years back to simulate balanced output. My brain must've forgotten! It is a long time since I've done op amp stuff and was never an expert to start with. Thanks for helping out with the schematic.
One question I have is: Do I specifically need capacitors in the gain stages of each op amp to prevent DC bias building up slowly? I've tried many circuits before and some op amps seem to stop working after a while as a DC voltage builds up on the inputs/outputs. Are some op amps just "better" than others in this respect?
Thanks for all your help guys. Really appreciate it! Top community.
