Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Basic wall wart AC question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Basic wall wart AC question (Read 2105 times)
sweesiong78
Contributor
Country:
on:
September 27, 2014, 02:04:40 am »
Why is it when I stick just one probe of my multimeter into the pin of a plugged in wall wart I can detect the 60Hz signal on my multimeter? how is the multimeter able to complete the circuit?
Logged
Psi
Super Contributor
Country:
Re: Basic wall wart AC question
Reply #1 on:
September 27, 2014, 02:10:08 am »
The single connection provides a AC cycle reference between your meter and the mains making it easier for the meter to pickup 60Hz RF noise in the air around you. At least, that is how it was explained to me. Because it's AC, mains gets transmitted into the air.
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #2 on:
September 27, 2014, 03:37:18 am »
Capacitive coupling into the other multimeter lead generally from earth ground can provide enough signal into the 10 Mohm and roughly 200 picofarad input impedance of the multimeter.
This is not recommended but if you hold one lead in your hand, you can use the other to tell the difference between hot and neutral or ground.
Logged
kolbep
Frequent Contributor
Country:
Reply #3 on:
September 27, 2014, 04:16:29 am »
If you do hold the other probe in your hand, double check that your dmm is not on resistance or current ranges #Ouch#Lfmf
Logged
www.ShoutingElectronics.com
Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
German_EE
Super Contributor
Country:
Reply #4 on:
September 27, 2014, 08:23:15 am »
I suspect that it is 50/60Hz fields. If I switch my bench DVM to 0,3VAC then I get a varying signal of about 0,15V with nothing attached and 0,26V with the leads plugged in but not connected at the other end.
Logged
Warren Buffett
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
