Hello All, I figured this might be a good place to enlist some extra grey-matter for a project I am working on. I want to add LED backup-lighting to my shop. Sort of falls in line with Dave’s recent battery charging videos.
I have a 18X24’ shop and I have acquired some free 10X3 LED lamps, (They are from street lamps that were knocked over). They are best operated from an 18 VDC, 1 amp supply.
I have a wall-wart that is supposed to supply 18VDC at 1A, but I only measure 16 VDC. I can run both lamps from the wall-wart and the light output is acceptable, but the wart voltage is around 14VDC at 3/4A. It gets warm but not hot.
I purchased two sealed led acid batteries, 6V @ 2.9ah and 12V @ 2.9ah. I hooked these in series for 18V and powered the lights for almost 2 hours (just what I want). Now how to charge the batteries back up.
The wall-wart only has 16VDC (although rated for 18VDC) so I added a 820 uF cap that brought the voltage up to 24V. I placed a small 12V lamp in series to limit the charging current. So far it seems to work. I have been charging the batteries at 18V for almost an hour and the voltage is staying steady at 18.5 VDC and the limiting light bulb is getting dimmer.
I want to finalize the charging design, and make the lights come on automatically with a power outage. Suggestions are appreciated. I mostly deal with transformers, diodes, caps and resistors, Please no exotic recommendations.
Some background, I used to repair Valve / Tube TV’s, built my own Valve / Tube amplifier. I work on 12VDC automotive / Tractor systems, maintain a Public Safety Radio System (my day job) and I built and wired my shop.
Really enjoy this forum, and Dave’s videos.
Hopefully the Pictures will show what I am trying to do.
