I'm pretty new to electronics, so I don't really have a huge amount of experience with this kind of stuff. I've been reading the Art of Electronics, listening to the Amp Hour and watching Dave for a while. I'm really stuck on a design I'm working on for a FIRST robotics team. I've tried to highlight my biggest questions in bold.
Throughout our competition, we have to keep batteries charged for our next match, and the time span for matches can be anywhere between an hour and a half during regular competition to about 10 minutes during the tournament, so we always have to have multiple batteries charged and ready to go. We are allowed to use two types of batteries, the MK ES17-12 and
http://www.mkbattery.com/images/ES17-12.pdf the Yuasa NP18-12
http://www.yuasabatteries.com/pdfs/NP_18_12_DataSheet.pdf. We will rotate battery use, but overall we'll use them for about 2-3 years before they're no good anymore and end up on a practice robot (and that's fine with us). Overall lifetime isn't exactly a top priority for us. At any given competition, we'll probably take 8 batteries with us. I would guess each battery sees maybe a total of 50 charges/discharges throughout its entire life. This is because we charge them at maximum charge rate of 6 Amps using this charger
http://www.walmart.com/ip/Schumacher-6-4-2-Amp-Charger-Maintainer/21642120 (You can get them anywhere, really).
Now our current issue is that we're pretty unorganized when it comes to battery maintenance, so we want to build a "cart" that will store batteries in slots for easy access and charging. We try to keep up with checking the internal resistance of these batteries before packing up to make sure we're not packing any "bad" batteries. What I would like to do is have an "all-in-one" solution battery cart that will automatically sense which battery is in a slot based on an RFID tag attached to each battery and a sensor in each slot. I'd also like to be able to display a "percent charged" on a battery-by-battery basis on an LCD screen. My biggest question is how I go about doing this. I have some ideas, and hopefully some smarter guys can tell me if they'd work or if they're half baked.
I think instead of making my own
Ni/Cd (Edit: Sealed Lead Acid) battery charging circuit, I'm just going to crack open the ones we already use and run LEDs to the front panel of the battery cart. That way, I can just throw in a beefy power strip inside the case and let AC power run to the chargers. In order to measure the internal resistance, I'll have to break the connection and use my own circuitry for that.
Should a use a solid state relay for that? To drive the LCD and deal with RFID stuff, I'll probably use an arduino.
Should I just use a wall wart to get my DC voltage to run the arduino (since I already have a power strip inside my case)? I also assume I'll have to worry about heat because it will be an enclosed space, so I'll need to put some fans inside as well.
Any other thoughts on if this will work or anything else I should consider? Also, is all I need to do to measure 6A is to put a low ohm resistor (like 0.001 Ohm) in series with the charging circuit and measure the voltage drop and use Ohms law? Thanks,
Michael
