Hello all,
Here's the circuit I have built. Vin is 4.96V from a regulated supply (computer PSU). Rprog is 2K (1%).
The charging current Output is only 140mA approximately. According to datasheet, it should be at around 500mA? Am I doing something incorrectly?
I have the MCP soldered to a SOT23-5 to DIP board and that DIP board soldered to a circuit on a phenolic board I etched. According to the datasheet, they recommend placing battery leads as close to the circuit as possible to avoid major voltage drops. My battery has AWG24 (solid) soldered to the leads that then solder to the circuit. Approx 15cm length each, so total 30 cm length. Could this be generating such high voltage drop? I mean, I'm getting essentially 1/3 of the charging current?
Thanks,
