Thanks for all the replies.
Well we started some reverse engineering, measuring and programming with arduino. For now the goal is to connect the back board with
arduino and let it control those two relay drivers depending on the inside temperature.
Good thing is that if MCU is not connected, the whole thing works in cooling mode, so no trouble there.
Now I have some problem to get proper reading from the NTC to the arduino. When I set up direct connection arduino, NTC and 10k restistor,
I was able to use the formula in here
http://www.instructables.com/id/Build-yourself-a-clock-and-thermometer/step3/Create-the-sketch-or-arduino/and I got results which seemed to be like 2 degrees off compared to thermometer I put inside. I realize, they are at bit different place, but
I also had the whole thing off for few hours to measure the room ambient temperature and still it was 2 degrees off.
The guy in link above gives a link for wiki where the formula should be explained, but I dont see there the same formula he
used plus for these formulas some parameters are needed. Can I somehow find out those parameters for my NTC?
I dont see any name or such on it.
Next is measuring the NTC outcome on the way do display. Here I found out there is 1k and 10k res on the way, as well as
capacitator. How do I calculate these in the formula? Reading in arduino was then 14 degrees off. If the behavior was linear
I dont mind and offset it by 14, but it will not be linear right?
One more extra question. There are two relays, each switch between ground and 12 V for peltier. To these the peltier
is connected as well as two fans. These fans are on manual switch to get 5 or 12V. But how come if polarity changes
fans dont mind that?
