Author Topic: 18650 parallel sanity check  (Read 192 times)
Offline paulca
« on: December 31, 2017, 01:01:32 am »
So I just want to check in case I've lost the plot, but...
I have some 18650 cells out of a brand new laptop pack.  They are factory paired in parallel.  I have put them into a 3 series 2 parallel configuration in an 18650 battery holder.
The cells are 3.7V 2600mAh each, so 3S2P creates a 11.1V (12.6V) 5200mAh pack (which was the rating on the laptop battery before I dismantled it).
This means to charge it at 0.5C I supply 2600mAh and charge to 12.6V.  For 1C fast charge I supply 5.2Amps, although I think I'll keep that to 5 Amp max.
Note, I have a standard balance lead wired to 0V, 3.7V, 7.4V, 11.1V and will be using a dedicated LiIo balance charger.
Current Open Projects:  3 Channel Audio mixer with DAC, BT, pre-amps and h/phone amp, WS281x LED controller Version 2 5V/5A w/Atmega328, FY6600 Power supply, 5A DC Load (Still!)
