You need a decent soldering iron, flux, solder, tweezers and probably a magnifier.
I think it's an 0402 size which isn't too bad to do. I'd recommend a soldering iron from JBC, Metcal or Pace. You'll struggle with almost any other. Depending on your eyesight, either a magnifying lens or a microscope so you can see that you have a good joint.
